Here's a link to the pics. The more I look at the engine and compartment, the more I think it was ridden maybe once or twice in its life. Sucker starts right up no problem. Whether it has 10 hours or 100 hours, is there any sort of maintenance I should do or anything I should check before I start putting hours on it? It is 18 years old, afterall. I've checked the hoses and rubber parts, nothing is dried out or cracking.
Does it have some sort of vacuum-based sump/bilge? I see something mounted to the bottom of the hull below the shaft with some hoses attached. Wondering what I should check or look for if I were to partially fill the hull with water to test it.
1994 Yamaha WaveRaider 700 - Visionary Photos | SmugMug
Any idea what this is for?
It connects to the back/bottom of the digital display.
