Alright, I inspected the nozzle and steering today.
I put the nozzle in the center manually, and the handle bars match up well, so whats else could be causing me to have to keep the bars to the left?
Could it be those crappy little stock sponsons on the xl700?
Also, about the reverse lever. Is there anyway I can adjust the lever postition?
I think when the lever is all the way down, it pulls it a little too far and make that noise with the steering. I have to keep it a tad above the flush line to keep it at the perfect position. If that makes any sense..
I found this out by closing the reverse latch manually by the nozzle, then sliding it back up, then I see that the lever isnt even all the way down. So I want to get it back in that same position, then just loosen the lever(if possible), and set it to the correct position..
Also, it is VERY hard to push the lever back into foward.. I almost feel as if the lever is going to break..
It opens and closes really easy manually when I do it by hand..
Any ideas?
Thanks!
