Thanks. I couldn't find info on the VX700 either, but forgot to mention it. The VX700 is heavier like you said, so it should use more gph. But it is a different hull profile, so I don't know how that change in hull affects it. The fact that Yamaha retired its XL hull suggests that maybe the VX hull is more efficient in the water, which might mean that the increase in weight might be negated in efficiency in the hull design, and then the XL700 and VX700 would similar in gph. I already know how much oil and gas our XL700s consume over the summer season, but I need a fairly accurate projection of what the fuel savings would be to figure out how much of our PWC fuel and maintenance budget we will have available to purchasing new craft. If I assume the VX1100 burns 3gph at 30mph which I've seen measured, and the VX700 is comparable to the XL700 burning 0.5gph more at that speed, then I should expect a 14% reduction in fuel costs on top of the 100% savings on 2 stroke oil, minus the cost of 3qt of 4 stroke oil with filter and 2 extra spark plugs at the end of the season. I was hoping for a more dramatic savings than that to help pay the steep cost of buying new craft over the next few seasons.
