Originally Posted by YamaDoo
1) Remove drain plugs at back of hull.
2) Remove spark plugs and crank engine (water should shoot out cylinder holes.)
However if the engine took in water and sat like that for 7 months you can surely bet on needing a new motor.
I believe i may be in luck!
1) hooked up battery. the dash works!
2) took out spark plugs, the motor cranks!!! had some water. maybe 1/2 cup?
3) all 3 cylinders seem too me moving and air is coming out of all 3.
4) i have a spark on the cords also!!
im hoping that i will be able to dry it and start it!
Is there anything else i should check or look for before i do?
Also if the engine cranks and no visible rust, does this mean i might be able to save the engine?? Thank you!!!
