There is no "kit", but it can be done and supposedly it's not too hard. The hull is the same on all models and the position of the cut outs and bolt holes should be marked on your hull.
Here is a "how to" that I copied from another site for someone else:
I've received various PM's concerning fitting reverse to a VX110.
Firstly, you can do this to all VX110's. They are all the same no matter the year.
It's very simply. Yes, you will need a drill but all the points to be drilled are marked on the hull already. One point for the reverse cable, to come through the hull, is a 2-3 inch slot so if you don't have a dremel you can drill a series of holes and then file it out. A hand operated rivet gun & basic metric tool kit will be required also.
1. Order all the Deluxe model parts. (List below)
2. Remove the front storage bin partition & seat.
3. Place a small plastic bag over the air box intake.
4. Disconnect the throttle cable from the TPS unit.
5. Disconnect the steering cable & Stop/Start connectors from the wiring loom
6. Remove the steering system. One bolt & nut at the base of the steering. Once you've removed it the whole column will slide out.
7. Remove the large plastic shroud. There are 8 bolts to remove to do this. 2 are inside the body of the hull.
8. Now you will see on the fiberglass body of the hull, approx where the reverse lever should be, some raised circles. They need to be drilled out to the size of the circle.
9. Remove the blanking grommet that goes through the rear of the hull. (The easiest way is to disconnect the exhaust hose on top of the plastic exhaust sound suppression box and move the box away to access the nut using some multi-grips).
10. Feed the reverse cable through the hole. Make sure the reverse cable has a rubber washer on the outside of the hull. Do not over tighten the nut otherwise you will ruin the washer & water can enter the hull.
11. Re-attach the exhaust.
12. Feed the cable through the slot you've made. Fit all hardware.
13. Remove the plastic bag from the air intake.
14. Replace the shroud. Put some Three Bond on the bolts. Secure it & fit the reverse handle.
15. Put some grease around the steering column bushes (it will remove the play that the earlier models develop). Replace the steering column. Reconnect the steering cable first. Connect the throttle cable & Start/Stop wiring.
16. Replace the partition.
17. Assemble the reverse bucket & attach. (Do not forget the spring otherwise the bucket continues to drop down while you're riding it).
I think I've covered everything.
It will take you about 2 hours to install.
Parts for 2005-2009 models:
1x 6D3-R1314-00-00 GATE, REVERSE
2x 90119-089UF-00 BOLT, WITH WASHER
2x 90387-08M30-00 COLLAR
1x 90119-069UX-00 BOLT, WITH WASHER
1x 90387-06M30-00 COLLAR
2x 90201-06801-00 WASHER, PLATE
2x 9538R-06600-00 NUT
1x 6D3-52358-00-00 SPRING, RETAINER
1x EU0-U1461-02-00 STUD, JOINT BALL
1x F1K-U826C-01-00 BRACKET
3x 90267-489U6-00 RIVET, BLIND
1x F1K-U134A-00-00 REMOCON. LEVER ***
2x 9572R-08300-00 NUT SELF-LOCKING
1x F1K-U2714-02-00 GRIP,HAND
1x F1K-U1336-00-00 DAMPER, STOPPER
1x 90151-05802-00 SCREW, COUNTERSUNK
1x F1K-6149C-00-00 CABLE,REVERSE
1x F1K-U1467-11-00 BRACKET,STOPPER CA
2x 90119-06858-00 BOLT, WITH WASHER
1x F1K-U146G-00-00 PACKING, CABLE
1x F1K-U1316-01-00 PLATE, STOPPER
Good luck!
