1987 wr500 elec help - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-12-2012, 06:15 PM   #1 (permalink)
Default 1987 wr500 elec help
hey everyone i just purchased a 1987 wr500 i picked it up real cheap and just want to get it running and flip it for cash to rebuild the top end on my newer ski, the guy i purchased it from said the cdi box is bad, now running i know there only valued around 500 so to buy a new cdi at 350ish isnt realistic. but i dont know how mechanically inclined the guy is, i just got the wiring diagram for this ski but i need to know how to check the stator, the cdi coil etc, i havnt turned it over to check anything yet, what am i looking for as far as voltages,ohms, i was told the stator send out a/c voltage and the cdi converts to dc and stabilizes the voltage any help is greatly appreciated, and if i find its bad if anyone has a cdi cheap i would be interested it has the 6k8-10 i read the 11 would fit if the coil was also replaced thanks everyone
acguyri is online now Report Post Reply With Quote
acguyri is offline   Reply With Quote
Old 05-12-2012, 10:28 PM   #2 (permalink)
I'd recommend you get a cheap service manual. It will have all the specs for checking out the stator. Ebay always has them. Seems like the output voltage is something like 30-50 volts AC, but it varies by rpm, so I don't remember all the specifics. Ebay is also your best bet for finding a used CDI.
Old 05-13-2012, 10:48 AM   #3 (permalink)
yea ive called all local boating stores barnes and noble etc nobody has a clymers or chilton available locally i was hoping someone had the same problem and could help thanks again
Old 12-31-2012, 12:39 AM   #4 (permalink)
Default re: CDI replacement
You can modify these easily and cheaply folks, as an ex electronics guy i have found the fix, the problem with most 500, 650 and some others is that the CDI box has a rev limiter, you can order a CDI through jaycar electronics $50 AUD, or you can order a high performance CDI off ebay.
The CDI off jaycar works like a dream, beware though the main diode coming off the charge coil may blow so replace with a 40volt 3 amp schotsky diode parallel with the 5804 diode.
Be warned though, this thing now flies but you need to limit the revs otherwise your head will blow.
viper000 is offline   Reply With Quote
Old 01-24-2013, 04:37 PM   #5 (permalink)
the damned thing blew again, so i tried the one below
High Performance Racing CDI For motorcycle GY6-Style engine Scooter DirtBike ATV | eBay
now it works much better, still watch out you don't let it over rev.
