2003 Yamaha Waverunner FX 140 error code - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 2 (permalink) Old 06-21-2012, 09:12 PM Thread Starter
Im trying to fix my friends Yamaha Waverunner FX 140. It will start and runs fine, however after a few minutes the check engine sensor goes off. When I held the two buttons down I came up with error code 63. From what I read on other forums this means "Air intake system malfunction". While we were looking at the engine we saw a lot of standing oil in the top of the motor near the air filter and the what we believe to be the carburetor. We were wondering if the oil could have shorted out a sensor. If anybody else has has similar problems please help.
thomas112 is offline
post #2 of 2 (permalink) Old 06-21-2012, 09:39 PM
It sounds like the engine is way overfilled with oil. Oil has backed up into the air box through the oil separator breather hose which is right under the fuel rail. If there is any oil on the air filter it will make it very hard for the engine to breath, and give you that code. This is a fuel injected 4 stroke ski..............there is no carburetor.
On this ski you can only get an accurate oil level reading when the engine is HOT. Never check the oil level with the engine cold, or it will read way low, and you end up overfilling it. You have to run the ski on a hose for at least 15 minutes to get close to an accurate oil level reading. You need to remove oil until it reads at the 1/2 way point between the marks on the stick when the engine is HOT...........right after you have run it.
If the air filter has any oil on it it will need to be replaced. Spark plugs will typically also need to be replaced, since the excess oil fouls them very easily.
Get the oil level right, new air filter if necessary, and new spark plugs, and this should fix the problem.
Ernest T is offline
Human Verification
