*HELP* XLT1200 PV will not stay running
Just bought my 2003 PV XLT1200 with D-plat & chip compression from the front #1-130 #2-140 #3-130, PV are working.
First thing i had to do was replace a fuse to get it to crank then i rebuilt the carbs cause there was milky oil/water substance in the cylinders & fouling out the spark plug's witch meant gummed up carbs... thank god i didn't buy something with a blown head gasket or worse.
I got the water and milky oil flushed out, put new plug's in and there clean.
My problem now is: It will only START & STAY running when plug's are pulled, fuel is poured into the cylinder's, plug's are replaced, START and have to keep the throttle mashed wide open (%100), let off throttle and it dies
