Winterization / Winter Storage Checklist - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 10-31-2012, 02:46 PM   #1 (permalink)
bgm1961's Avatar
Default Winterization / Winter Storage Checklist
All,
Hello, I’m new to this forum… as I’ll likely post a question or two for help, I’d like to start by offering a Winterization / Winter Storage Checklist & Maintenance Record (attached), put together by referencing the owner’s manual and culling various posts in this and other online forums.
NOTE: I originally created the checklist as a professional-looking pdf document, assuming it would be OK to upload a pdf. If I had bothered to check the allowed files types before trying to upload I would've figured something else out. In the meantime, the checklist is attached as two jpegs. The resolution is bad which I apologize for. I'll have to see if there's another way to make a pdf available to this community - any suggestions would be welcome.
The attachment is a combined checklist and maintenance record form. Next to each step, there’s a space for you to record materials used, observations, etc. Some may find this handy to keep a history of winterizing actions in your files.
I don’t have much winterizing experience so I know there’s always room for improvement. I would love any criticism or feedback to make the product better for this community to use!
Also, the checklist has a blank space next to most steps, for you to write-in/reference the applicable page numbers from your specific owner’s manual. I have a 2011 VX Cruiser, so for those of you referencing the 2011 VX series Owner’s/Operator’s Manual, the page numbers are listed below for your convenience.
Thanks!
bgm1961
********** 2011 VX Series USA Owner’s Manual Page Numbers ********
NOTE: This list is NOT the same as the complete checklist in the attachment! Below are only those items that have a corresponding page number in the owner’s manual.
Page numbers from the 2011 VX Owner’s Manual (USA, 1st ed., May 2010):
PRE-OPERATION CHECKLIST (Pg 57)
FLUSH COOLING SYSTEM (pg 78)
CHECK OIL QUANTITY (pg 52)
INSPECT & LUBE SHIFT CABLE (pg 82)
INSPECT & LUBE STEERING CABLE (pg 82)
INSPECT & LUBE THROTTLE CABLE (pg 82)
ENSURE WATER SEPARATOR IS DRAINED (pg 35)
CLEAN ENGINE & INTERNAL COMPARTMENT (pg 79)
DRAIN ENGINE COMPARTMENT (pg 54)
GREASE LINKAGES w/ MARINE GREASE (pg 82)
FOG ENGINE WITH FOGGING OIL (pg 83)
REMOVE, SERVICE, CLEAN, & STORE BATTERY (pg 80)
RUSTPROOF ENGINE & COMPONENTS (pg 83)
WAX HULL (pg 82)
Winterization / Winter Storage Checklist-pg-1-waverunner-winterization-checklist-maint   Winterization / Winter Storage Checklist-pg-2-waverunner-winterization-checklist-maint
bgm1961 is offline   Reply With Quote
Old 10-31-2012, 05:32 PM   #2 (permalink)
Nice Job! Should be a sticky!
