2012 VX Deluxe Winterizing Questions - Page 2 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 12-25-2012, 07:44 PM   #11 (permalink)
Oh ok. Thanks. I need to order me up a grease gun with extension hose now.
LVNeptune is offline   Reply With Quote
Old 12-26-2012, 12:13 PM   #12 (permalink)
Got any recommendations for a grease gun and extension hose (I assume I'll need an extension hose?)
EDIT:
Also is this OK for spraying down the engine bay to help prevent corrosion?
Amazon Amazon
Old 12-27-2012, 04:34 PM   #13 (permalink)
Just about any full sized grease gun will work. You can get the hose extensions to attach to the gun separately.
The silicone spray from Amazon is good for rubber and plastic stuff. For metal, I recommend one of these 3:
1. Fluid Film
2. CRC 6-56
3. Corrosion X
Fluid Film is probably the 2nd best and most cost effective, but a little hard to find. Its the one I prefer for spraying down the engine and components. It tends to stay in place and can be sprayed on anything without harm. Some guys spray it on the outside of their ski, claiming that it works better than wax and prevents water spots. I get it off Ebay. CRC 6-56 is easy to find, cheapest, but probably the least effective of the 3. Corrosion X is probably the best for actually preventing corrosion and can be sprayed on electrical components, since it is a dielectric, but its a little expensive and harder to find. I like to use it on electrical connections, and they make a heavy duty version that is great for spraying your trailer parts with, since it stays in place even after water exposure.
Old 12-27-2012, 04:38 PM   #14 (permalink)
I will look into those, thank you. A little OT but can I use that stuff I linked on Amazon for the bellows on my boat?
Old 12-27-2012, 05:49 PM   #15 (permalink)
xxMoving Target's Avatar
http://www.yamaha-motor.com/yamalube...ts/348/details
I've never used the yamalube spray but according to the description I read it should be fine.
As for the fluid film, its also what I use, here are a couple of links for different places. I'll let you do the math for which is cheaper. The first link is where I ordered my first batch from last year and had no problems.
Fluid Film Rust Protection
Amazon.com: fluid film Amazon.com: fluid film
fluid film in Business & Industrial | eBay
Also when I greased bearing/housing I took out the bolts that hold that metal plate with electric box (ECU?) on it and had extra set of hands hold it up so I wouldn't have to unhook wiring to make it easier to get to fitting. If you do this be careful. It seemed as if the bolts had loctite or something on them. It would suck to spin out those bosses in that plastic or fiber glass piece (not sure what its made of).
Good Luck
xxMT
xxMoving Target is offline   Reply With Quote
Old 12-27-2012, 06:03 PM   #16 (permalink)
Ack. Plastic/fiberglass threads suck
Old 12-27-2012, 06:18 PM   #17 (permalink)
Maybe bosses is the wrong word, threads are metal inserts kinda like this. Still scary if something bad happens, I just didn't have an extension and couldn't reach.
Old 12-27-2012, 06:20 PM   #18 (permalink)
I'm sure it'll be OK.
Old 12-28-2012, 05:05 PM   #19 (permalink)
Yea that stuff is pretty safe for everything: metal, wood, rubber, plastic, etc.. Won't hurt anything spraying it on metal, but doesn't have the corrosion protection that the other products mentioned have. I spray it on the rubber stuff inside the engine compartment.
