+1 on what Outlaw said, but with your FXHO the air intakes offer a direct route to get fogging oil into the system without removing the plugs, so here is a really easy solution:
1. Start the engine and rev it up a few times to blow any excess water out of the exhaust system. Don't run it more than 15 seconds. Wait 2-3 hours and repeat.
2. When the engine is cool again, remove the air box lid and the air filter. Start the engine again and spray fogging oil in to the 4 intake openings through the ribbon assembly while the engine is running. Spray for about 3-4 seconds into each opening but don't run the engine longer than 15 seconds. Put the filter and box lid back on and your done until the spring.
Not a bad idea to pull the battery and put it on a trickle charger, or charge it every month or so.
