losing speed and power? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-23-2008, 06:29 PM   #1 (permalink)
Default losing speed and power?
Help! We have a Yamaha 2006 VX 110 Deluxe. I can normally get it up to 55-57 MPH. All of a sudden today, it will only go 47-49MPH. It also feels like it isn't as powerfull. I had no reports of anything wrong from the kids that rode it yesterday.
I checked the grate and it looks fine...no weeds or anything else in there.
Its not in learning mode,
Any suggestions on what might be wrong, or where to look?
At current top speed, the engine seems to have a whawha noise to it that is new.
Thanks for your help!
Mary
arctica is offline   Reply With Quote
Old 07-23-2008, 07:48 PM   #2 (permalink)
JUST-IN-TIME's Avatar
need to plug it into yds
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 07-23-2008, 10:56 PM   #3 (permalink)
Default whats yds
I do not know what yds is.
Old 07-23-2008, 10:58 PM   #4 (permalink)
yamaha
diagnosis
system
Old 07-24-2008, 08:19 AM   #5 (permalink)
Get your remote and try switching the setting Low/high
Let me know. The kids might have switched it on you.
bpann1 is offline   Reply With Quote
Old 07-24-2008, 09:41 AM   #6 (permalink)
Default Low/High
The kids have not had access to the remote. When it is in low mode, the machine won't go more than about 30-35.
My problem seems to be some lack of power, and a loss of about 10 MPH at top RPMs. I have the grate off and there is nothing in the impellor, although the edges of the impellor are very slightly ragged. Could that be the problem?
Could sand do that?
The kids were beaching it the other day, they promised me that they cut the engine in 3 ft. plus water......but you know how kids can be.
Old 07-24-2008, 01:42 PM   #7 (permalink)
that could do it
Old 07-28-2008, 01:56 AM   #8 (permalink)
Default Checked these things out
I changed spark plugs, found the air filter to be clean and dry, I checked the fault codes....there were none. The engine sounds and feels fine except for the loss of top end speed and power.
Does that leave me with the impellor as the probable culprit? Or are there other likely causes? Can I use the machine without fear of wrecking it? I will take it to a pro and have it hooked up to the Diagnosis machine if you all think that I still should.
thanks for your help!
Mary
Old 07-28-2008, 10:14 PM   #9 (permalink)
Default impeller pics
I have attached a of pic of my impeller. Could the ragged edges be the cause of my losing top speed?
I changed spark plugs, checked for fault codes, checked the airfilter....everything was normal.
What else can I do before I go to the pros?
Old 07-28-2008, 10:22 PM   #10 (permalink)
yes that could do it
