92 waverunner 3, can't shut it off!!! HELP! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-03-2010, 12:31 AM   #1 (permalink)
Default 92 waverunner 3, can't shut it off!!! HELP!
This is my buddy's ski. He just got it running the first time this year. We hooked up the garden hose, fired it up, turned on the water... I turned the idle up a bit to keep it running... a couple minutes later it sounded like it was about to die, so i told him to goose it. He did and it reved up and wouldn't slow back down when he let off. He pulled the dead man key, still running. He pulled the plug wires, STILL RUNNING!! So i shut the choke butterfly and it slowly came to a hault. WTF??
You're a daisy if you do.
Loanshark is offline   Reply With Quote
Old 09-03-2010, 08:33 AM   #2 (permalink)
YamaDoo's Avatar
It was running with the spark plugs wires disconnected? If so that is REALLY weird.
Old 09-03-2010, 01:25 PM   #3 (permalink)
He pulled the plug wires off the plugs and there was no change. It was very weird. I've never seen anything like it. I'm hoping someone has...
Old 09-30-2010, 04:15 PM   #4 (permalink)
Yeah its not weired... Its the high compresion of the engine, the spark plugs glow red making it react like a spark plug. Also 2 strokes can also start up on there own if there hot.
chrissdouglas is offline   Reply With Quote
Old 10-15-2010, 06:47 AM   #5 (permalink)
This is called a lean runaway by some.
I have reference to this and other stuff in the Jet Ski Chronicles....
Yamaha1100JetSki : Yamaha 1100 Jet Ski PWC JetSki
fredt is offline   Reply With Quote
Old 10-16-2010, 03:21 AM   #6 (permalink)
Default What happened to my 1995 Polaris SLT 750?
I was crusing at about 40% power, when suddenly the engine quit. I tried to restart, but the engine was siezed. Using channel lock pliers, I was able to rotate & unlock the engine at the jet pump coupler.
I removed the 3 sparkplugs & was able to spin the rngine freely with the starter. Also, all 3 cyl have sufficient compression. After reinstalling the 3 plugs & wires, I tried to start the engine, but it just sputters like it is out of time & it also tries to sieze again.
I feel something is trying to come loose in front of engine, in the timing gear mechanism?? Has anyone out there experienced same situation & pinpoint my problem before I tear into the engine?
SBR RIVERMAN is offline   Reply With Quote
Old 10-16-2010, 10:31 AM   #7 (permalink)
Default Had a similar problem
See my earlier post.
I went through that with my ski also.
