No spark 95 waveblaster 1 701 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-04-2011, 07:22 AM   #1 (permalink)
Question No spark 95 waveblaster 1 701
Just when I thought this ski was indestructable.... I uncovered it, primed it, she started for 10 sec then quit. Stuck a screwdriver in the boot, cranked it w/ the shank close to ground and no spark. During cranking I pulled the kill lanyard and the starter stopped, does this mean my kill switch is good or are there 2 separate circuits to that switch 1 for ign 1for start. I do not have a wdm or serv/ manual but good working knowledge. I could use some help on ohms, volts #'s from the diff coils and wire colors. Actually any help would be appreciated. Bat is almost new and fully chged. Thanks.
niteridder64 is offline   Reply With Quote
Old 08-12-2011, 10:55 PM   #2 (permalink)
I have a manual now and checked all connections and all 3 coils ohm out great. Which coil would I check for voltage while cranking and how much vac should I get, the pulse ,charging or the lighting coil. The stop and kill switch are good there is no corrosion and all wiring is good. Need help Thanks.
Old 08-22-2011, 10:39 PM   #3 (permalink)
Default Fixed !
The cdi checked out bad so put in a new one today and runs great.
