The bilge pump only runs with the engine running, and for about 30 seconds after. You can hit the start button repeatedly just enough to get the pump to come on without the engine starting, but you may drain the battery. The drain plugs are too high to be any use unless the ski is really full of water.
My recommendation is suck it out with a wet/dry vac. That is what I do after a ride, and if you don't let water sit in there the bilge stays clean. You can also put it on a hose and run it, but the bilge pump will not remove it all.
