Originally Posted by xenus7850
My questions are:
1. Does the ski have to be on in order for the bilge pump to get water?
2. If the fuse is good, what other reason would there be that the pump is not getting power to run?
1. The bilge pump only operates when the engine is running and for about 30 seconds after you shut it off. It is strictly manual and it does not have an automatic feature or float to detect water.
2. It should run with the engine on, and you should hear it running for around 30 seconds after you kill the engine. If not you may have a bad connection somewhere or just a bad pump.
For your use, storing the ski on the water, I'd look at installing an automatic bilge pump. You may also want to look at an additoinal battery for use at the dock.
