96 wave venture 1100 engine issue - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-14-2011, 10:17 PM   #1 (permalink)
Default 96 wave venture 1100 engine issue
I have a 96 wave venture 1100 triple. The problem is it wont idle for more than a few seconds and it likes to bog down when I hit the gas. However today it got pretty bad. At one point I was doin a straight run for maybe 50 yard and it just died outta no where. The guy I bought it from said it gets a little too much oil which I guess is better than not enough right? But it almost seems like its interupting the burning and compresion process in the cylinders. And would it be possible for it to be too much compression and lift the head or affecy the valves ect... In hoping its only a dirty fuel filter if it has one. Anyone have any advise or tips??? Thank you
Backwoodsrebel is offline   Reply With Quote
Old 08-21-2011, 11:21 AM   #2 (permalink)
i thinyou need to get a little more info on your ski befor jumping get a repair manual ill try a little help for you frist do compression test you can rent one from parts store if your going to stay in pwc sking buy one there cheap if comp is good great you have to elimnate this frist gas filter is on right sid if you were sitting on the ski frist thing remove filter try to dump fuel from filter in to a jar let it sit awhile and see if it seperates thats water if you cant get enough fuel from filter get a quater inch outboard fuel line ball get clean jar put ball onthe tank side of the fuel filter look at arow on filter pump about 4 or 5 ozs into jar let sit and look at it if it has water youll have to pump out tank and have carbs overhaul if no water great to much oil?very rare could happen? ask the guy you got it from if the carbs where ever done if not ill bet they need to be ethenol in gas is killing carbs if this seems too much take to repair shop let them ck it then mabe you can fix it hope this helps
junebug is offline   Reply With Quote
