No reason that I can see for it being hydro-locked, but depending on how long you ran it after the oil light came on, I'd suspect that you may have ruined one or more cylinders and you could have done other internal damage. Running an engine even for a very short time with no oil can cause major damage.
How much oil did you put back in? With the engine cold where is the oil level on the dipstick?
I suspect you killed your battery with all the starting attempts. Try it with a new battery first. If you can get it to turn over then go to next step.
Next step is to do a compression check then I could tell you more. Pretty easy to do: pull the spark plugs, insert compression gauge with extension that matches the spark plug length into a cylinder, hold the throttle wide open and crank. You want to see 164 psi or more (it may be a little low on a cold engine). Put a couple of drops of oil into the spark plug hole and try it again and see if the number changes. If you don't feel confident doing the compression you could take it to and auto mechanic, and get it done.........it would be pretty cheap. Just remember to tell them to hold the throttle wide open when they do it.
If you get some compression numbers, I can tell you more, but at this point it doesn't sound good. Engines on these things are pretty hard to damage, but once they are, fixing them is a real bitch (and not cheap).
I'll provide all the help I can, and there are other guys on this site than can help as well. Save your $$$, you will probably need them for the repairs.
