I've heard heat it and pry it up, but not much else. Yamaha doesn't show the material they use for the sealant in the service manual. I suspect (guess) it is a form of Threebond gasket material, because they use this material on several other areas of the ski for a sealant. I don't recommend using it as a replacement, because it obviously failed the first time. You might try using a gasket removal spray and let it sit for a while to see if that loosens it up.
