It doesn't take too much damage to the impeller to cause you to loose power. Did you check the impeller to housing clearance? It should be less than .45 mm around all the blades. Bends and dents in the impeller will cause cavitation, and power loss. My guess is that you will need a new one, or find a good repair shop that can repair the original.
