1995 wave raider trouble - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-27-2011, 06:16 PM   #1 (permalink)
Default 1995 wave raider trouble
HELP !! 1995 wave raider wont start after warmed up and bogs when turning left under power
ske65088 is offline   Reply With Quote
Old 08-27-2011, 08:13 PM   #2 (permalink)
Fuel flow problem most likely. Dirty filter, dirty carb., etc.. When is the last time the carb was rebuilt? Probably time to do it again.
Old 08-28-2011, 09:03 AM   #3 (permalink)
Thanks Ernest T I don't know if they have ever been rebuilt. This seems like a very common problem with waverunners from what I have read. Do the newer 4 stroke waverunners have the same problems?
Old 08-28-2011, 08:07 PM   #4 (permalink)
Carbs. need to be cleaned and rebuilt on any 2 stroke engine. My father had an outboard engine that required a carb. rebuild every 2 years, or it just wouldn't run right. Your ski is way overdue. Most guys recommend doing at least a good cleaning/rebuild ever 3-4 years (even if you don't put that many hours on the engine, fuel will cause varnish to develop and that is even more so with ethanol fuels). You can get the carb. rebuild kits and do it yourself for $50 or less per carb. Its not that hard, but labor intensive, so it can be expensive to have a dealer do it.
The joy of the 4 stroke skis is that they are all fuel injected, so there are no carbs. to worry about or mess with. I've got a 4 stroke outboard on my boat now too, and I can tell you I'd never go back to a 2 stroke engine.
