Usually means a fuel restriction causing leaning. Since you just cleaned the carb, and filters they should be good. You mught try richening the mixture by a very small amount (maybe 1/8 of a turn), to see if that helps. Can also mean the pop off pressure is off, so that would be something else to check.
