2001 Waverunner XLT1200
2001 XLT 1200 with 72 hours
I took my wave runner out a couple of weeks ago and after running strong for about an hour it stalled on me. I was able to get it running again but had to constantly feather the throttle to get it back to shore. Got it back home, pulled the plugs to performed a compression check and noticed the middle cylinder had been detonated. I am looking for the root cause of this issue since I do not want to perform a rebuild only for it to happen again.
Performed a compression check on the three cylinders 105 / 0 / 105.
Performed a pressure test on the crank case and noticed I have a leak in the rear main seal with no other leaks.
Inspected the reed valves and noticed that three of the eight for the middle cylinder where way out of the .010 gap tolerance.
I am getting ready to rebuild the carbs.
My question is what do your think could be the cause of the lean cylinder causing the detonation.
