Be sure to read through the owners manual about how to reset the lock code. You have to completely reset it or you will not be able to start the ski. You should see "Start" on the display once you are done.
Make sure the battery is showing 12.5 volts unloaded. Look for a loose connection first. Trace the leads from the battery to the starter, starter solenoid, etc.. Take the start/kill switches apart and look for loose wires and corroded connections. Make sure there is nothing stuck in the pump.
Once you are sure all connections are good, try jumping the starter solenoid (jump the 2 large + wires). If it starts you have a bad solenoid. If it doesn't start, pull the starter and connect it directly to the battery with a set of jumper cables and make sure the starter spins. If not you have a bad starter. If the starter spins when not connected to the engine, pull the spark plugs and be sure you can turn the engine over by hand. If not your engine is locked (blown).
