Bogging while turning - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 29 (permalink) Old 08-14-2018, 07:08 PM Thread Starter
New to forum today...2003 Xlt 800 from slow idle Bogging bad while turning and slight hesitation going straight from dead stop. Changed plugs first, Rebuilt carbs still having the problem. Runs great all other times compression is about 100 on both cylinders, also drained all gas during carb rebuild and changed tank vent due to pressure build up. Any help would be greatly appreciated.
metz1234 is offline
post #2 of 29 (permalink) Old 08-15-2018, 05:28 AM
The tank does build pressure when not used and in the sun. The vent lets air in but not out. 100psi is low. Should be closer to 140ish. When you rebuilt the carbs, did you reuse the old needle springs ? Did you set the mixture screws back to factory settings ?
rodsatheart is offline
post #3 of 29 (permalink) Old 08-15-2018, 09:15 AM Thread Starter
Does it build enough presssure to blow the cap out of your hand and break the chain?
I read on here not to use the new spring so I didn't on the needle in the carb sort of like a regular float needle. These were mike I carb kits. The only thing I didn't rebuild was the small pump on the top of the front carb and was thinking of doing that next not sure what that one does. I did put the carb back to factory setting and I think it was 1/2 turn out on one and 2 out on the other for both carbs
metz1234 is offline
post #4 of 29 (permalink) Old 08-15-2018, 09:17 AM Thread Starter
Mikuni not mike spell check got me
metz1234 is offline
post #5 of 29 (permalink) Old 08-15-2018, 09:19 AM Thread Starter
Were you talking about high and low speed needles and springs? If so kit didn't come with that I cleaned and put back
metz1234 is offline
post #6 of 29 (permalink) Old 08-16-2018, 11:52 AM Thread Starter
anyone have any ideas on what the problem is and what does the small pump on top of the front carb do?
metz1234 is offline
post #7 of 29 (permalink) Old 08-16-2018, 07:13 PM
Dave in DE's Avatar
Rods was asking if you used your old spring from your needle and seat valve inside the carb?
Your problem could be your accelerator pump. Witch is the small pump on top of the first carb. You'll need a new diaphragm and make sure the nozzles in both carbs are clear and clean. They tend to get corroded. You can find the diaphragm at SBT.
Dave in DE is online now
post #8 of 29 (permalink) Old 08-16-2018, 07:25 PM
There are screws on the side of the carbs. Did ou mess with them, and if so, did you put them back to exactly the setting they were in ?
Dave's right on the rest.
post #9 of 29 (permalink) Old 08-17-2018, 05:46 AM Thread Starter
High and low speed jets were put back exactly and the nozzles were clean I will order diaphram. So should I change springs on needle inside carb while I have it Apart?
Thanks for the help
metz1234 is offline
post #10 of 29 (permalink) Old 08-17-2018, 07:14 AM
Dave in DE's Avatar
No. It's best to use old springs. Just make sure there set correctly.
Similar Threads
JS 440 bogging while ridding Kawi Kawasaki Jetski 2 09-07-2011 05:41 PM
550 not turning over, not a battery issue. mbdiesel Kawasaki Jetski 8 04-04-2009 01:19 PM
X2 not turning over TiggersDaMan Kawasaki Jetski 2 07-07-2008 11:42 PM
84 Kawasaki JS550 not turning over mbdiesel Vintage Jetski 4 05-20-2008 06:04 PM
1988/89 Yamaha WR500 Not Starting/Turning Over CaptnTony General PWC & Jetski Discussion 6 08-29-2007 10:24 PM
