05 STX 12 F weird stuff - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 17 (permalink) Old 06-14-2018, 07:38 AM Thread Starter
Ok. I went out on my ski last week and everything was fine. I came home and flushed it out and stored it in my garage. Yesterday I changed the battery out and then tried to start it. It sounds like it is bogged down when starting and sounds like metal on metal grinding in the rear of the ski. It cranks 3 times and stops and then the power goes off and then on again all by itself. I checked the intake grate and it is not plugged up. Now it won’t crank at all. What is going on.
Jtzb03 is offline
post #2 of 17 (permalink) Old 06-14-2018, 08:59 AM
Pump bearings might have gone out. Pull the pump and see what happens. Disconnect the fuel pump so it wont start when you turn it over.
rodsatheart is online now
post #3 of 17 (permalink) Old 06-14-2018, 12:11 PM Thread Starter
Now I can’t get the jet pump off. I have tried pulling prying banging 2x4 and everything. I think this was the problem all along. What you you thing. Maybe a bent shaft rod or impeller not on straight.
Jtzb03 is offline
post #4 of 17 (permalink) Old 06-14-2018, 03:24 PM
I believe there are 2 bolts that hol it to the ride plate. Did you get those also ?
post #5 of 17 (permalink) Old 06-15-2018, 05:18 AM
Is this a salt water or fresh water machine ?
post #6 of 17 (permalink) Old 06-15-2018, 11:13 AM Thread Starter
Yep. I took off the ride plate and all. I just can’t get this thing off. Is there something I am missing. Everything is unscrewed. Is it because it’s so jammed up that it won’t come off or do I have to go in the battery compartment and unscrew the 2 hose clamps on the drive shaft to see if the person before me jerry Rigged. It comes out about 2 inches and the drive shaft moves too. I see it going back and forth when I try to pull the pump off back and forth. I’m screwed aren’t I.
Jtzb03 is offline
post #7 of 17 (permalink) Old 06-15-2018, 12:04 PM
Sounds like the drive shaft is stuck in the impeller. It is just a slip spline fit and should slip apart. If you have a heat gun you can try and apply heat to the the impeller at the drive shaft but be carefull you dont get the hull to warm.
post #8 of 17 (permalink) Old 06-15-2018, 12:47 PM Thread Starter
I’ll try that. Thanks for all your help so far.
Jtzb03 is offline
post #9 of 17 (permalink) Old 06-15-2018, 05:08 PM Thread Starter
It still won’t come off. I give up. I have taken every option and tried it and it is being a pain in the azzzz. I don’t know if I should just take the whole engine out and start from scratch or just sell the dam thing.
Jtzb03 is offline
post #10 of 17 (permalink) Old 06-15-2018, 06:20 PM
Is there a driveshaft seal on the impeller and if so can you reach it to slide it back on the driveshaft. If so, spray some liquid wrench down in the impeller.
Similar Threads
Kawasaki 1100 stx weird problem Orangen1 Kawasaki Jetski 0 09-04-2014 11:10 PM
Shred Master Ride Plate KAWASAKI 1200 STX-R -12F -15F -09-12 STX Txstick PWC Jetski Classifieds 1 03-16-2014 10:33 AM
No Compression in One Cylinder/plus some other weird stuff ZackRB42 Yamaha Jetski 6 08-18-2012 02:52 PM
12.2......12.1......12.0 volts....kept dropping gregpwc Yamaha Jetski 3 04-15-2012 07:21 AM
05 f-12 non turbo need tech help or parts bmwtech Honda Jetski 0 03-04-2008 10:17 PM
