Hasn't Run for Two Years - Any Words of Advice? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 15 (permalink) Old 06-18-2018, 02:47 PM Thread Starter
My generous brother-n-law gave me his 1998 Kawasaki STX 1100. It was been sitting in a garage for the past two years with out it ever being started. He did put sta-bil in the fuel prior to storing. It is extremely clean and ran great before it went into storage. He said all it needs is a new battery, which I have just ordered from amazon.
My question is, prior to me attempting to start it for the first time in two years, is there anything I need to do? I'm afraid to do any damage to the motor since it has been running for such a long period of time. I want to keep it in great shape.
Thank you in advance for the help.
fat-tire is offline
post #2 of 15 (permalink) Old 06-19-2018, 05:27 AM
Prob. should rebuild the carbs., but at least look at the oil injection lines. They should pliable and secure. I would premix about two gallons of fuel to equal 32:1 total. The injection system mixes at 50:1, so you just need the difference. I think it's like 1 1/2 onces per gallon, but double check it. Crank it in short 3-5 sec intervals to get fuel to the carbs. No more than 10 sec, then rest. Pull the plugs and put a tablespoon of oil in each cyl and turn the engine by hand with the drive shaft. I would get a couple sets of plugs. One for now and one for later. Don't let it run more that 10 sec with no water, and be very carefull if you run it on the hose as the front cyl will get hot in a hurry.
rodsatheart is online now
post #3 of 15 (permalink) Old 06-19-2018, 08:39 AM
Lee Taylor's Avatar
Some amateur advice here. Having the Sta-bil in the fuel is great and I do the same but I would remove the fuel and put in fresh fuel.
Owner. Rider. Maintenance. 17yrs.
2002 Yamaha. FX140. 1000cc. Cruiser. Collectors model.
2017 Lowes Stryker 16. Mercury 50hp 4-stroke.
Lee Taylor is offline
post #4 of 15 (permalink) Old 06-19-2018, 08:43 AM
Lee Taylor's Avatar
More amateur thoughts. Getting a bit of lubrication on the cylinder walls will not hurt a thing
post #5 of 15 (permalink) Old 06-19-2018, 09:29 AM Thread Starter
Thank you for the quick reply and good advise. Do I need to add grease to anything?
fat-tire is offline
post #6 of 15 (permalink) Old 06-19-2018, 02:35 PM Thread Starter
I took the cover off last night and snapped a few pics of the engine compartment. I thought I'd share for fun / comments.
ID:	16829   Click image for larger version
ID:	16831   Click image for larger version
fat-tire is offline
post #7 of 15 (permalink) Old 06-20-2018, 03:57 AM
That thing looks immaculate !!!! I think you need to donate it !!!!!!
What's up Lee ? Haven't seen you in a while.
post #8 of 15 (permalink) Old 06-20-2018, 07:34 AM
Does your Ebox sit dead center of the Driveshaft or is it more toward the battery? My fiberglass has pre-drilled holes, but if I mount using the holes, my positive cable from the Ebox will not reach positive post of my battery.
SIMPLEARKANSAN is online now
post #9 of 15 (permalink) Old 06-20-2018, 09:12 AM Thread Starter
Hahaha! Yes, it is in great shape. He always takes good care of this things.
fat-tire is offline
post #10 of 15 (permalink) Old 06-20-2018, 09:16 AM Thread Starter
I'm assuming Ebox means electrical box. Are your referring to the silver box in this pic? As you can tell, I don't know a lot about these things. I can take another look at it to properly answer your question. However, I do believe it sits dead center of the driveshaft, right behind the motor. I'm pretty sure there hasn't been any modifications made to the Jet Ski. So, i'm sure this is how it was manufactured.
fat-tire is offline
Similar Threads
Sitting for two years with hull damage and trim inop. canadian_fly Kawasaki Jetski 2 02-02-2012 07:50 AM
Two Boats, Two Trips, Same Results jetskibrian General PWC & Jetski Discussion 6 01-03-2011 05:21 AM
Hasnt Run in years! snotrocket Sea-Doo Jetski 1 07-14-2010 07:14 PM
I got the "Seal Of Approval", two papers in two weeks! jetskibrian General PWC & Jetski Discussion 0 04-28-2010 06:39 AM
