2000 1100 stx di - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 19 (permalink) Old 07-03-2018, 06:16 PM Thread Starter
2000 1100 stx di
Starter relay is disconnected. When positive cable touches battery the engine cranks. Master switch is off too.
skidad89 is offline
post #2 of 19 (permalink) Old 07-03-2018, 06:38 PM
Then the relay is bad.
rodsatheart is offline
post #3 of 19 (permalink) Old 07-18-2019, 08:52 AM Thread Starter
I am looking for someone who has a copy of KADIAG for a Kawasaki 1100 stx di. I took the motor out to replace the driveshaft seal and now have engine light on. ski ran great before that. Any thoughts ?
skidad89 is offline
post #4 of 19 (permalink) Old 07-18-2019, 06:44 PM
Any other symptoms ?
post #5 of 19 (permalink) Old 07-18-2019, 09:02 PM Thread Starter
after hooking everything up and cranked it, the engine light was on. ran the ski on trailer in water and had rough idle, adjusted the tps and did better but the ski is in SLOW mode ? the cps checks good resistance. the ski ran flawless before I pulled the motor. Im at a loss? I have an old laptop that would probably run KADIAG, looking for a download..
skidad89 is offline
post #6 of 19 (permalink) Old 07-19-2019, 04:50 AM
You need the adapters and cables also. Is there anything else showing up on the dash like temp, oil, fuel.... ? Did you get the cooling lines hooked up correctly ? have you done the cooling mod and checked the stator cover and emm for corrosion yet ? Have you checked the air temp sensor ? Did you mess with the idle setting ?
post #7 of 19 (permalink) Old 07-19-2019, 08:26 AM Thread Starter
cooling lines were crossed but fixed that, oil res was and light came on so oil is full now, drained old fuel replaced with fresh gas, emm and mag hook up looked good but did not look too close in female end, did mess with tps cause at first would not idle, now idles around 1200 rpm in water, injector hardness had 2 small wear spots on wire, wrapped them with e tape, have not tried to sync the throttle body, bleed the oiler "got smoke", temp light was not activated, did pull the cps out and looked at it.. hope its not out of adjustment, have not pulled stator cover, blew out water lines with air, they are clear..has new fuel filter, pulled the return line off at check valve and it had lot of pressure in line is that normal ?
skidad89 is offline
post #8 of 19 (permalink) Old 07-20-2019, 03:16 AM
That check valve is the pressure regulator. You adjusted the tps or the idle screw ? It should be holding 1100 idle in or out of the water. Tps has to be set with a dvm. Inlet on the cooling lines goes to the bottom of the exhaust manifold. Make sure your getting spark at all 3 plugs. Do a ohm check on the cps. They are known for the wires to break right at the sensor.
post #9 of 19 (permalink) Old 07-20-2019, 09:55 PM Thread Starter
cps ohm tested good, spark in all plugs. I set the throttle body by manual, adjusted tps, do you know where I can download KADIAG, would like to get see codes...
skidad89 is offline
post #10 of 19 (permalink) Old 07-21-2019, 05:26 AM
Getting the stuff for you. Just by chance, did you remove the injectors at any time ?
Similar Threads
2000 1100 STX DI swamped Steveski Kawasaki Jetski 0 09-20-2010 12:01 AM
2000 1100 STX DI - Eng9 error code lwsumrall Kawasaki Jetski 0 07-03-2010 10:03 PM
My 2000 1100 STX Di is missing a little SSThunder Kawasaki Jetski 0 07-15-2009 03:10 PM
2000 Kawasaki 1100 stx di whosyrdady Kawasaki Jetski 1 07-05-2009 01:39 AM
Winterizing 2000 1100 STX DI BUDDY LEE Kawasaki Jetski 0 09-19-2006 02:07 PM
