Kawasaki 1100 STX DI Diagnostic Software - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 25 (permalink) Old 12-11-2018, 02:40 PM Thread Starter
I recently purchased a non-running 1100 STX DI and I need a copy of the 57001-1461 diagnostic software. Anybody know where I can get a copy of it?
Thanks,
willno
willno is offline
post #2 of 25 (permalink) Old 12-12-2018, 04:35 AM
I downloaded a copy somewhere, but I'll have to hunt. All the components can be checked with a ohm/volt meter. If all are good, prob. the emm. First one to check is the crank sensor.
rodsatheart is online now
post #3 of 25 (permalink) Old 12-12-2018, 09:37 AM Thread Starter
Thanks for the reply and the info. If you can find out where you down loaded the software, that would be great. By the way, does it run OK on newer versions of Windows?
willno is offline
post #4 of 25 (permalink) Old 12-13-2018, 05:09 AM
I never used it. It was just to much money for me to spend for everything else.
post #5 of 25 (permalink) Old 12-13-2018, 09:17 AM Thread Starter
OK, thanks.
willno is offline
post #6 of 25 (permalink) Old 12-14-2018, 04:29 AM
Do you have spark ? Are the injectors firing when you crank it over ?
post #7 of 25 (permalink) Old 12-14-2018, 08:06 AM Thread Starter
Just ordered a new battery and haven't received it yet. I'll keep you posted.
What's the best way to check the 45V injectors?
willno is offline
post #8 of 25 (permalink) Old 12-15-2018, 04:20 AM
Check it at the injector itself, but keep the harness plugged into the injector. If you take a small piece of wire (like 20ga), strip off about 1/2" of sheathing, twist and solder it, it makes for a nice probe that you can get past the water tight seal with.
post #9 of 25 (permalink) Old 12-15-2018, 11:22 AM Thread Starter
Sorry I'm new to this DI stuff. Ok, and then I'm looking for the 45Vs with the probe when I crank the motor over? Is that what you mean?
willno is offline
post #10 of 25 (permalink) Old 12-16-2018, 03:52 AM
Yes. You will hook the ground of the meter to the battery, probe the positive at the injector and measure the cranking voltage. The reason you want that high voltage is that the injectors actually produce the high fuel pressure, not the pump. The pump just keeps then supplied, unlike a automotive system where the pump provides the pressure. If the running pressure is low, it will create a lean condition.
The big problem with the 1100Di's is that the cooling for the emm gets restricted by corrosion and overheats the emm frying it. If it runs, the first thing you need to do, if it hasn't already been done, is the cooling mod, and pull the cooling cover off the stator cover and clean it.
Similar Threads
Looking for kadig software for kawasaki 2000 1100 stx di. dfrancescato New Member Introductions 0 05-06-2014 10:24 AM
Kadiag software for stx1100 di ? smille5291 Kawasaki Jetski 0 07-18-2013 02:54 PM
Yamaha Diagnostic Software throttle valve question BenFX160C Yamaha Jetski 0 03-19-2013 07:46 AM
Yamaha Diagnostic software 02yamahafx140 Yamaha Jetski 4 07-07-2011 09:54 PM
Watercraft Computer Diagnostic Software iare General PWC & Jetski Discussion 1 10-23-2009 02:47 PM
