Options to get spark - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
LinkBack Thread Tools
Old 02-07-2019, 04:26 PM Thread Starter
1999 Kawi ZXI 1100, the electronic box (computer?) is waterlogged and I cannot find a replacement. Are there any options I have so I can get spark?
swimmer_spe is offline
Old 02-08-2019, 01:55 AM
The cdi box is sealed. All of the components are available except the cdi box. You just need to open it up, dry everything off, and check all the connections. Is this a new to you ski, or did it have spark before ? Have you tried new plugs and trimming the plug wires about 1/2" ?
rodsatheart is online now
Old 02-08-2019, 10:10 AM Thread Starter
It is new to me. A friend had a problem with no spark. I determined that the CDI box got water in it. The cables going into the box no longer are sealed at the openings of the box. Everything in the box are corroded.
Old 02-09-2019, 04:57 AM
Chances are the actual cdi is good. Look into getting a new rectifier, pull all the connections apart, clean them, and apply some dielectric grease when reconnecting them. Make sure you get the ground location on the box clean, and you might look into making a second ground wire out of 6ga wire to go from the engine to the electrical box. I attach it to the drive coupling cover and just come straight across to the box and attach it to one of the cover bolts. I would also do some ohm testign on the coils to make sure they are good.
It's very common for those plastic pieces to break. You can buy new ones. They are kind of a pain to replace. You can also just use some 100% silicone to seal them. it will look like crap, but will water proof it.
If you don't have it yet, do some hunting, and download a manual for it. It will have all the specs for testing the coils, stator, and cdi along with a wiring diagram.
Old 02-09-2019, 08:58 AM Thread Starter
What do do with the box that is also corroded? Seriously, if someone has a whole thing, I would replace it.
Old 02-09-2019, 10:02 AM
What box are you talking about ? The whole electrical box ? That is just a case for all the components inside (coils, rectifier, cdi box, starter relay). All those components are replaceable. Not not sure if the cdi box is in production anymore though. The upper and lower halves of the electrical box can be cleaned inside and out.
Old 02-09-2019, 02:46 PM Thread Starter
Yes the whole electrical box. I have scrubbed it and used various cleaners but it is still corroded and am getting dust from it. All of the connectors are corroded. Any bare wire is corroded.
Old 02-10-2019, 07:10 AM
The only way to get 100% of it out is to have it media blasted. Water makes it corrode, so each time you get it wet, it will corrode a little more as it drys. Just use a small wire brush to loosen up what you can and blow it out with compressed air (away from you).
You can clean the connections with 320 grit or finner emory cloth or 600 grit sand paper. Try some white vinegar and baking soda, rinse, dry, and finish with a small brass wire brush to clean the wires.
If your just tired of messing with it, and want a nice clean water tight box, I found this one on ebay. Looks to be super clean, and the sealing nuts appear to be fairly new.
https://www.ebay.com/itm/Kawasaki-ZX...frcectupt=true
Old 02-10-2019, 09:27 AM Thread Starter
Thank you for the link. What years did the CDI box run for that will work on mine?
Old 02-11-2019, 03:54 AM
Shows 1997-2003.
Similar Threads
Our First PWC - Input on Re-fueling Options Please DevotedDad General PWC & Jetski Discussion 7 05-01-2012 10:32 PM
Buying a PWC for the first time two options Mdezinno Sea-Doo Jetski 1 04-22-2012 11:19 AM
XLT800 needs a new engine....what are my options? wattsbarxlt800 Yamaha Jetski 10 07-17-2011 05:21 AM
traction mats: wat are my aftermarket options? poser General PWC & Jetski Discussion 1 03-18-2011 11:52 PM
FX High output insurance - options? icancupee Yamaha Jetski 10 06-03-2008 12:20 PM
