2000 STX 1100 Stalls - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 7 (permalink) Old 04-30-2019, 03:25 PM Thread Starter
A friend of mine just bought at 2000 STX 1100 3-seater. It starts up but after a few minutes dies and won't start again unless sitting about 10-15 minutes. The cycle then repeats at shorter intervals. Any ideas?
gilberts is offline
post #2 of 7 (permalink) Old 05-01-2019, 07:22 AM
The Di is prone to a big issue, but when fixed, is a great ski.
Are you getting the over heat warning ?
I'm betting the emm is getting hot. It is water cooled, and the passages get corroded and plugged. You do the cooling bypass which bypasses the stator and creates a direct feed to the emm, and ads a seconds pisser so you can monitor the water flow.
I would also do a compression test to make sure the engine is not failing. Should be 135-145.
I would also look into replacing the crank sensor, as the wires are not supported very well, and have a tendency to break at the sensor.
rodsatheart is offline
post #3 of 7 (permalink) Old 05-01-2019, 11:10 AM Thread Starter
Thanks for the info. The EMM is the electronics module?
gilberts is offline
post #4 of 7 (permalink) Old 05-01-2019, 11:27 AM
Yes, it's mounted right under the front seat hook between the engine and gas tank.
post #5 of 7 (permalink) Old 05-01-2019, 11:58 AM Thread Starter
Thanks! And where is the crank sensor located?
gilberts is offline
post #6 of 7 (permalink) Old 05-02-2019, 07:42 AM
On top of the stator cover right above the oil pump. Looks just like a std crank sensor with a 10mm head bolt holding it in. You can't miss it.
You can check it with a digital ohm meter. I forget what the spec is on it, but it's in the manual. Just wiggle the wires when testing.
post #7 of 7 (permalink) Old 10-09-2019, 06:51 PM
still having issues?
Backyard mechanic.
2000 Kaw STX 1100, ďThe BeastĒ,
2008 Kaw 15F.
Jgreenwood is offline
Similar Threads
98 GTX Stalls at 3500 rpms Csonka Sea-Doo Jetski 2 10-06-2008 06:52 PM
2001 STX DI Runs great/stalls Normal Kawasaki Jetski 0 09-04-2008 12:26 PM
2001 Virage, runs but stalls and no idle. 2001Virage Polaris Jetski 0 08-26-2008 01:15 PM
stalls and won't turn over 6atenza220 General PWC & Jetski Discussion 0 06-16-2008 05:21 PM
650 STD stalls only at full throttle pls3 Polaris Jetski 2 08-20-2006 09:11 AM
