Cheking for spark - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 8 (permalink) Old 05-18-2019, 02:14 AM Thread Starter
Cheking for spark
1999 Kawasaki ZXi 1100
I plan to get it back in the water. I was given it from a friend, knowing full well it was not running. He was getting no spark. I was given it in boxes.
So, now I want to get it running. How can I test things like the stator and the other electrical components to figure out exactly what is causing the no spark before throwing parts at it.
So, how do I figure this all out? I am knowledgeable on cars, but not jetskis.
swimmer_spe is offline
post #2 of 8 (permalink) Old 05-18-2019, 05:29 AM
Could be the cdi box, rectifier, stator, coils, or just needs the coil wires replaced or trimmed a bit (yes it's possible, and needs solid core wire). It could also be a corroded connection in the electrical box. Has it ever been submerged ?
First thing is get a good agm battery for it, rebuild the carbs (might even look at getting a set of cdkII carbs instead of using the crap CV carbs), replace the oil injection lines and fuel lines.
Find a pdf of the service manual. It will have all the specs to check all the electrical components.
I would also get a GOOD compression gauge and do a compression check, but first put a tablespoon of 2 stroke oil down each plug hole and turn the engine by hand to coat the walls, rings, and pistons.
I have a ZXI manual and will try and post up some pages.
rodsatheart is offline
post #3 of 8 (permalink) Old 05-18-2019, 07:07 PM Thread Starter
I have a manual for it.
I have a good battery for it. The carbs are good. The compression is good too.
The problem is lack of spark.
post #4 of 8 (permalink) Old 05-19-2019, 07:59 AM
So I'm assuming you have gotten new plugs ? Open the electrical box inspect everything for corrosion and broken terminals ?
Make sure the grounds are good, clean and tight. I've been known to add a 6ga ground from the engine to the electrical box for extra measure.
Start with checking the easiest and most obvious things. Could be the coils, but they rarely go bad. It's usually the plug leads that deteriorate, and they can be replaced with some solid core wire, but it's kind of a pain. Try removing the plug caps and trimming the lead 1/2" or so. If you don't have a digital meter, get one. They're like 30.00 at Autozone. Your going to need it. Check the coils primary and secondary winding's, and check the rectifier. The spec's are in the electrical section of the manual. I have gotten ski's that had so much water get in them over the years from the broken plastic nuts that the wires enter the box through, that the terminal blades on the rectifier corroded and broke off.
post #5 of 8 (permalink) Old 05-22-2019, 03:08 AM Thread Starter
I have opened the box of mystery. It looked very white inside. I there aa way to bench test the box?
post #6 of 8 (permalink) Old 05-22-2019, 05:02 AM
Each components needs to be checked individually at this point.
post #7 of 8 (permalink) Old 05-22-2019, 07:31 PM Thread Starter
How do I do that?
post #8 of 8 (permalink) Old 05-23-2019, 05:16 AM
You need to get a decent Digital volt/ohm meter and use the manuals instructions. Everything has specific measurements.
Similar Threads
1994 Kawasaki 750SS. Spark for two seconds and then no spark krupster Kawasaki Jetski 0 09-15-2009 12:17 AM
