Grinding Noise from back of ski - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 6 (permalink) Old 08-04-2018, 11:54 PM Thread Starter
I have a 1994 polaris slt750, and when i was on the water today the engine stopped abruptly. I tried to start it back up but it would not run as there was some grinding in the back, i assume the jet pump, that was stopping the engine.
Staruskib87 is offline
post #2 of 6 (permalink) Old 08-05-2018, 08:02 AM
Sounds like it. I would inspect it from the intake and discharge sides before pulling it. You might have sucked up a rock or other debris.
rodsatheart is online now
post #3 of 6 (permalink) Old 08-05-2018, 09:45 PM Thread Starter
I did not see any debris in the intake and discharge. so i am going to take out the pump and replace the bearings, does anyone know of a video on how to take the pump out? im pretty sure i can figure it out but i just want to be sure before i break anything.
post #4 of 6 (permalink) Old 08-06-2018, 06:15 AM
From what I see it looks straight forward. Remove steering cable, 4 bolts holding the nozzle, 4 bolts holding the pump, hoses inside that attach to the pump. It's prob. going to have silicone on the transom mating surface so it will be stuck pretty good. Clean that surface and apply pure silicone sealant on reassembly, and new orings on the cooling tubes. Apply marine grease to the driveshaft splines on reassembly.
post #5 of 6 (permalink) Old 08-06-2018, 06:47 PM Thread Starter
Thank you, do i need to worry about taking any bolts out from the driveshaft holding it together? or should it just pull right out when i've removed the hoses and bolts?
post #6 of 6 (permalink) Old 08-07-2018, 06:23 AM
Pump should just slip off the driveshaft.
Similar Threads
97 Polaris SLT 700 (grinding noise) yamahaboy Polaris Jetski 0 08-02-2012 07:00 PM
Grinding noise, vibration in rear ? help !!!!!!!! AQUATRAX R-12 X Honda Jetski 4 06-23-2011 07:31 PM
grinding noise at not at idle njcruzer Honda Jetski 7 06-22-2011 08:32 PM
2005 Waverunner XL110 "Grinding" noise at low RPM amissner Yamaha Jetski 4 07-08-2010 09:49 AM
Please help! HondaR12x making grinding noise HondaR12x400ex Honda Jetski 1 06-17-2009 04:43 PM
