2003 Virage - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 10 (permalink) Old 05-20-2019, 09:34 AM Thread Starter
2003 Virage
Just picked the 03 Virage up to mess with, as it wasn't running from PO. This my 1st jet ski and after looking inside kinda lost. When I got home battery was @5 volts. No water so charged overnight and got up to 12 volts.
Went to try and start nothing so checked fuses 1 blown replaced now gauge lites up , no start just a click. Noticed the connector to the solenoid was lose but it just turns won't tighten.
Could that be the problem?
jterr is offline
post #2 of 10 (permalink) Old 05-20-2019, 05:06 PM
Check the voltage when trying to start it. Needs to be better than 10.5-11 when you hit the button. Is it a single click, or rapid clicking ?
rodsatheart is online now
post #3 of 10 (permalink) Old 05-20-2019, 07:16 PM Thread Starter
1click and like I said one of the connections on solenoid is loose and just spins when trying to tighten
jterr is offline
post #4 of 10 (permalink) Old 05-20-2019, 07:27 PM
Single click is prob because of the bad connection.
post #5 of 10 (permalink) Old 05-20-2019, 07:30 PM Thread Starter
Will have to replace as there is noway to get off without destroying. Thanks
jterr is offline
post #6 of 10 (permalink) Old 05-21-2019, 05:53 AM
It may be cross threaded. Try removing it with the cable, secure the relay to a bench, put a wrench on it, and hit the wrench with a hammer or something. The fast shock may loosen it. If not your going to have to cut the nut.
post #7 of 10 (permalink) Old 05-30-2019, 08:09 PM Thread Starter
Replaced the solenoid, battery cutoff and buttons on handle bar and got it to fire and ran just a bit. Question is now why is the Forward / Reverse lever so hard to move. It seems to be binding up. Where to check??
jterr is offline
post #8 of 10 (permalink) Old 05-30-2019, 08:41 PM
Prob the cable but i would lube all the pivot points first.
post #9 of 10 (permalink) Old 05-30-2019, 10:23 PM Thread Starter
Is there a diagram showing these, and how it is supposed to work?
JT
jterr is offline
post #10 of 10 (permalink) Old 05-31-2019, 05:42 AM
Here's a great post about it. Look down a bit and there's step by step instructions.
How to repair a stiff/jammed Reverse lever on Virage, MSX, Genesis with reverse lever
Here's some more Polaris info that should interest you.
https://sites.google.com/site/polarispwcknowedge/Home
Similar Threads
2003 virage i Oil Pump? Rhino99TJ Polaris Jetski 5 03-06-2017 07:14 AM
2003 Virage I Computer Module rickst1967 Polaris Jetski 0 07-12-2011 09:59 PM
2003 waverunner 1300gp & 2003 waverunner 800gp knarfoh Yamaha Jetski 0 08-23-2010 10:31 PM
2003 polaris Virage I weewun Polaris Jetski 2 06-21-2010 10:46 PM
2001 polaris virage trouble TRL24 Polaris Jetski 3 08-21-2006 11:33 PM
