Milky oil in cylinder - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 8 (permalink) Old 05-13-2019, 08:11 AM Thread Starter
Hi everyone- I have a 99 gts that was having trouble starting. I checked the plugs. One looked the ok. The other was milky and gross. I took the carb off and found that milky crap coming out of the pulse line. It was also in the carb. What could it be? I have a carb rebuild kit but if I rebuild it now the milky stuff would probably fill the carb again. Help! Thanks!!
Katherine24 is online now
post #2 of 8 (permalink) Old 05-14-2019, 05:23 AM
Sounds like water in the crank case.
rodsatheart is online now
post #3 of 8 (permalink) Old 05-14-2019, 11:13 AM Thread Starter
Is there a way to get water out of the crankcase?
post #4 of 8 (permalink) Old 05-15-2019, 05:21 AM
The question should be, how did the water get in there in the first place, and how much ? It is possible it was not witerized properly, or not at all, and froze and cracked the head or cyls, or leaking head gasket.
Water is detrimental to crank bearings, hence the reason to act very quickly to a ski that has been submerged. You only have hours before rust forms on the bearings.
You have two options to get the water out. Pull the engine, tear it down and spit the cases and check the bearings, and check the head, cyls, and exhaust manifold for cracks, or run it very easy on the water at operating temperature for about 15 min (but I would refrain from this until further investion eliminates the possibility of cracked or leaking engine components).
post #5 of 8 (permalink) Old 05-15-2019, 07:14 PM
Check the oil pump breather intake. I submerged my 2002 fx140 and fought milky oil for weeks before finding the breather hose was off and the nipple sat in bilge water sucking it in anytime I ran the engine. Replaced the hose and another oil change and it runs great.
beef1337 is offline
post #6 of 8 (permalink) Old 05-15-2019, 08:23 PM Thread Starter
Unfortunately it wasn’t winterized. Is the oil pump connected to the carb?
post #7 of 8 (permalink) Old 05-16-2019, 04:24 AM
This is a 2 stroke. Completely different animal. There is no breather on the oil pump.
The oil pump is on the front of the engine.
Does it freeze where you are, and is it stored outside or in a somewhat climate controlled inside storage ?
I would do a compression check and see if the numbers match on each cyl. to start.
post #8 of 8 (permalink) Old 05-16-2019, 06:50 AM Thread Starter
It gets very cold in western NY. I’ll check the compression. Thank you
Similar Threads
vx1100 with oil in cylinder sab3r Yamaha Jetski 10 06-10-2012 12:32 PM
2004 FX Cruiser HO gas in cylinder and oil sdgSomerset Yamaha Jetski 3 10-09-2011 06:50 PM
1996 sea doo gsx massive oil in one cylinder. pkexcavating Sea-Doo Jetski 0 06-26-2011 01:40 PM
1996 gsx sea doo, blowing oil from front cylinder.. pkexcavating General PWC & Jetski Discussion 2 03-22-2011 05:31 AM
SP Oil filling front cylinder Special k Sea-Doo Jetski 2 11-18-2009 09:29 PM
