After looking at the prices on new fuel pumps, I figured I would ask around and see if anyone else had experienced the same issue. I was riding for an hour last weekend and it was running great. I dropped down to an idle, it sputtered and then cut off. After about 5 minutes it started again and ran great back to the dock until i let off the throttle. Once it started to idle again, it sputtered and cut off again. I have spark, my plugs aren't fouled, the gas isn't bad, but I am not getting fuel. I took the fuel line off of the fuel rail and put the lanyard on... no gas. I checked voltage at the pump from the harness per the instructions in the manual and within a couple of seconds of inserting the lanyard, I have battery voltage. I was going to take the pump out and bench test it with 12V, to see if the pump works. Any thoughts?
