I just got 05 FX HO, changed oil, plugs, air filter, did all the neccesary maintenance stuff, took it to the lake, and couldn't start it for 10min. Finnaly when i had it running, it wouldn't idle i need constantly hold it reving. So it shutoff on me in the midle of the lake, tryed to start it till battery died, some good samaritan towned me to shore... Got home decided to check fuses, 3 AMP fuse was blown, replaced it, as soon as i tryed to crank it up i can see fuse blowing at the moment engine turns.... Engine starts after couple of attempts only and doesn't idle, fuse is blowing, i went through 3 of them.......HELP!!!!! Thank You
