When the ski idles or is ran slightly above idle for long periods of time it smokes a lot and is bogged down. When you go to jump on it its all loaded up and needs to clean out before it can take off. Once its been run hard it cleans out and works perfectly. Is there a way to fix the smoking/ loading up issue on the idle end? Its really annoying.
The only mods I have are the D-Plate, EFI Controler, Ride Plate. This did this both before and after the D-Plate and EFI Controller were installed...
