hi, im a technician in training at wyotech daytona, located in daytona beach florida. im enrolled and two months from graduation in the off road power program my program covers jet skis, atvs, snow mobiles, utvs, and dirtbike/asian sports bikes. heres what i know based on what ive read. one, even though the motor turns over a load test should be done to battery first. you can do this yourself if you have a load tester, if not i would remove the battery and take it to a shop, or even a auto parts store. once that is done if the battery checks out then i would begin chasing voltage. of you have access to a service manual for your machine you will need to find the wiring diagram. if not either purchase one of try to google search it. you need to know the path electricity is supposed to take to you ecu and from ecu to your display. im not sure if the display effect this models ability to run however what i do kno is your not expirencing a starting circuit problem. you either have a fuel delivery problem or ignition circuit problem because the starter is turning the moter. i agree with the guy who says suspect the ecu and wiring harness. your starter circuit is independant of your main harness i believe. so with a DVOM(digital volts ohms meter) you must check for voltage into you ecu and out to the rest of your componants. if your machine is fuel injected then a loss of power to ecu will shut down both fuel delivery and ignition as well as everything else. its very hard to isolate a ecu as the problem but if everything else checks out then the ecu is the only thing left. if you would like i would be more than happy to assist you in checking your systems via this forum. good luck
