Hi Community,
I've got a 1100 ZXI ('97 or '98) which doesn't seem to run quite up to spec and I'm asking for advice. I also posted questions about my INOP 750 ZXI under a separate post.
PRESENT CONDITION
Starts, but if cold a little hard. Lots of cranks.
Once running stays running.
Some hesitation on reasonable acceleration (not abrupt acceleration but what I would term "normal" application of throttle)
Compressions (cold) 120,121,121
New plugs
Top speed on the speedo about 53 under ideal conditions (flat, trimmed up, clean plugs) and I'm inclined to believe the speedo. Ran alongside other boats and there was good correlation
Factory oil injection, at idle plenty of smoke which I'm guessing is ratio not ideal when running slow. Doesn't surprise me.
I've been adding just a little oil to the fuel "just in case". Maybe 150:1.
QUESTIONS
1. Are compressions OK?
2. What can I do, if anything, for the hard start?
3. In terms of working through the hesitation, and/or limitation on top speed, any suggestions? Where should I start? Rebuild carbs?
4. What should I expect for top speed?
5. Should I yank oil system and just do premix?
6. Is my strategy to add some oil sound?
I really appreciate the help.
Doug
PRESENT CONDITION
New plugs
QUESTIONS
Doug
