I'm not actually sure the cylinder is #1, but it is the one nearest to the front of the ski.
What happened was some friends were out riding when the motor completely died on them. Tried restarting it a couple times, with no luck. I did a compression test, and the other 2 cylinders are around 110psi, while cylinder #1 is around 25psi.
I pulled the head off today. I have pictures attached. The piston was obviously hitting the head. Also, that cylinder is dry, whereas the other two had some oil/gas on the cylinder and piston. The other thing is that piston has a little bit of play in it, whereas the other two do not.
I just recently installed WaveEater clips, so I know it's not the pv. I'm almost thinking an oil line got pinched and because of that I damaged a connecting rod or something. There isn't any oil in the hull, so if I wasn't getting oil it's because a line got pinched.
I'm planning on pulling the cylinder off tomorrow and seeing what damage I find underneath that piston. Any ideas in the meantime?
Also,
-From this point, what parts should I plan on buying? Will I need a new piston or head? I've noticed that spark plug doesn't screw in like it used to. I wonder if I warped the head...
-Can I reuse the gaskets? I have some Permatex Copper Gasket spray I used installing my d-plate. Can I just use that?
-Should anything else be done while I've got this torn apart? I'd really like to get it running asap while it's still warm out.
Also,
