1 - 4 of 4 Posts
Purchased a non running wavejammer, it had no spark and original coil was missing. I have relaced coil and pulser coil with new because it tested bad. Charge coil tests ok. Is there any way to test the CDI with a multimeter? I really want to get this thing going but I don't want to spend another $350 bucks without being sure. This is my first PWC but I have worked on older boats, atv's, cars, RV's, appliances.
Discussion Starter · #3 · (Edited)
Are you getting voltage to the coil? Mine had a similar problem, had voltage to the coil but no spark even though it cranked good. Turned out to be a faulty kill switch.
There is novoltage to the coil during cranking and I disconnected kill switch during the test for spark. I have a manual but the only test for the CDI in the manual uses a special tester that I don't have.
1 - 4 of 4 Posts
