I am having an issue with it running lean at idle/low rpm and falling on its face if I open it up from anything below 1/4 throttle. The low and high speed screws are supposed to be 1 1/8 turn out +/- 1/4 turn. I left the high speed alone since it runs OK up top and found the low speed screw 2 turns out. I set it back to where it should be as a baseline but it runs worse now. However, it runs pretty well with the choke on. I already ordered a genuine Mikuni rebuild kit, and the fuel filter is brand new so here are my questions:
1. Based on the fact that the thing runs well with the choke on is there anything in particular I should be looking for or at when I tear the carb down?
2. This carb has 3 mixture adjustments. Low speed mixture, high speed mixture, and idle mixture. At what point does the low speed mixture screw take over from the idle mixture?
We're going away in 2 weeks on vacation with this ski and I'd like to have it running pretty well before we go.
Thanks.
John
Thanks.
John
