1990 Kawasaki 550sx fuel problem.
I have been trying to get this ski working all summer, I can get it to start if I choke the carb, and plug the hole on the choke plate to force the fuel into the carb. It will then stall, once I start to open the choke. It simply stops getting fuel, no matter what I do with the throttle. Now the weird part is that once in a while, I can get it to start (w/ normal choke), and run just fine (idles just fine). I try again later, & it just will not start. Arrrg.
I have rebuilt the carb 2 times. Cleaned it and blown it out several times. I have tried bypassing all the fuel lines. Fuel filters are clean. Both spark plugs spark fine. I have replaced the pulse line. I can feel the air pulsing through the pulse line to the fuel pump. Engine compression is 150 in both cylinders (and holds). Fuel consistently gets to the fuel pump, but not the carb chamber. I even took a carb from a 1987 550 and put it on this ski. It ran for about 2 minutes in the water and died, and never started again.
I bought this ski last year, and it ran great all summer. At the end of the summer this started to happen. It sat in a shed for the prior 10 years, and is in absolutely mint stock condition.
Any fresh ideas?
Any fresh ideas?
