Take a non-resistor spark plug (not an extended tip spark plug)
and bend the bridge back flat away from the electrode. Test the
spark against a head nut or other ground source. This is a load test.
If it can jump the ~1/4" gap, it will fire under compression.
If it fails the load test, you need to do an a/c voltage test on the
stator.
Bill M.
DId it run on a prime?
stator.
Bill M.
