i am about to buy a 91 super jet 1300$ does this sound like a good deal he says it runs good and offered to take it to the lake to prove it does anyone know if the 91s had any problems
Superjet is a superjet. They are all the same theory. Compression test both cylinders before you buy it. Make sure it is a premix. Otherwise install block off plate. oil pumps are bad juju.
compression should be at 120 each cyl or foul play! And 1300 is good if the boat passes compression test. You can buy a compression gauge at any auto parts store. Plu in to the spark plug holes one at a time and fire the engine for 2 seconds...one thousand one and so on. Leave the other spark plug in the hole or it will misread. Capice:appl:
I just bought a 94 701 for 1800 , but its absolutely cherry, I think it depends on the cosmetics, assuming it runs good. It would have to be pretty ragged to not be worth 1300, superjets rock.
