I just got this 92 650lx from a friend to check out and and see if itis fixable. It is very corroded and may be froze up. What should I check first to determine if it is even worth fixing? What can I spray on the engine to remove corrosion? I thought about putting something in the spark plug holes like some oil or transmission fluid to lube it and see if it will turn over. Last, how can I turn it by hand to see if it is stuck? I also don't see how to hook water up to it, hoping there was a picture or video of connections to flush it if it cranks.
rhutson
rhutson
