Got issues!
Bone stock! Runs fine out of water reving it, starts fine and idles fine. It dies just before plane consistantly (just before you try to stand up) in the same part of the powerband. I can feather the throttle working it until it gets past the dead spot and then it takes off .....stay on the throttle and the top end runs wide open perfectly. Once you let off the throttle it reverts back to that same flat spot..(just before plane). My thought was the cdi so i figured i would put the aftermarket one on to give it more power since i wanted more top end anyways and if it didn't fix the problem i would start replacing other things that might fix the problem. The MSD Enhancer was installed and the problem got worse?? All over the powerband. Could this be the Coil??? That was my next guess. Could it be that water temp sensor??
Any help would greatly be appreciated.
Thanks in advance.
Thanks in advance.
