check and double check all your grounds. Electrical and water dont get along to well lol. After you've checked your grounds you can try a few other things, first cut off about 1/4'' on the plug wire at the boot and reattach the boot and recheck. If still no succes start looking at the coil. If your coil has a white wire on it pull the white wire off and install a test light and crank the motor. If it lights up, you have power going to the coil just not out. Start with the cheapies first ( replace complete plug wires ) if that doesnt work your probably going to be looking at a coil. If the test light doesnt come on start looking at wiring/stator or possibly an MPEM. Just because it "looks" new doesnt mean its working. Hope this helps!
