I ordered an aftermarket rectifier from my local mechanic for the one sled that is not charging the battery and he advised me on the other that is bogging down to check the voltage at the battery and if goes above 14.4 volts when its reved up then the rectifier is bad and is probably the problem. Only issue is I will not get the machine in the water till the weekend to check so if it IS the problem I will not score a new rectifier for it till next weekend. Then there is still the inevitable grey hose issue to look forward to. Question is what size is it and what to replace it with. As they say , its always something!
